WebDav Sync Not working anymore
Hello,
I received this evening a strange error code from Enpass while trying to synchronize vaults through webdav. Error code : 906405.
I checked all evening for updates or login error on my NAS (containing webdav server), router errors/updates and found nothing. Nothing changed on my Enpass configuration and yet, my desktop app (windows store) won't synchronize (while my phone is still syncrhonizing with the same configuration/adress).
I just found out that yesterday enpass desktop app was updated by windows store. I am wondering if there is any bug on that last release or if I need to search again on my side.
Thanks,
BR
Thibault
Edited by hebusthib
  • Replies 73
  • Views 56.8k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Don't buy Enpass. This support sucks. They're kidding us. They've been doing that for years. They write that they will fix the problem in the next update. That never happens. They want a demo account
  • David Jameson
    David Jameson
    They have been discussing this for two years --- I'm done with them! Such a shame, enpass seemed like it was going to be my lifesaver. So I just bought Strongbox (Mac version of Keypass) and disc
  • Hello, I have the same issue. My IPhone is still syncing, but my PC (Windows 10) issues the same error Code 906405. Is there any place where i can find log data to provide for an analysis. V
Posted Images
Hello,
Version of Enpass 6.8.0 (1002) (was updated on 12.3.2022) since then i have the problem.
BR
Alex
Edited by ade
Hi @hebusthib@ade
Thank you for reporting the presence of this issue in our Enpass beta version. It will be fixed in the upcoming update. We appreciate your patience in the meantime.
#SI-2681
Hello,
just a short question, you mention that this is a beta Version. Is Version of  Enpass 6.8.0 (1002) a Beta Version?
Is it possible to turn of the automatic update, or switch to the normal Version?
I was not aware that I installed the a Beta Version.
Thank you very much by the way.
BR
Alex
Edited by ade
Hi @ade
The Enpass version 6.8.0 (1002) is a beta version.
I got it checked, and it seems that you are added to our beta version program; that is why you received the update. You can either disable automatic updates for your apps from Microsoft Store or let me know if you wish to be removed from our beta version program. After that, please create a manual backup/set up cloud synchronization on your device and reinstall the app.
  • 2 weeks later...
Any news about the fix?
It's incredible. I can't use webdav as a Premium member!
@TheRock64Sadly not. My last info was a week ago from the support and they said that this problem is in the current beta and will be fixed. But without any ETA.
I have now installed the stable version and the webdav sync works now again.
  • 2 weeks later...
On 3/16/2022 at 12:44 PM, Abhishek Dewan said:
Hi @ade
@Abhishek Dewan please remove me from the beta version program
  • 2 weeks later...
Hello,
I just got updated to version 6.8.0 (1048) and thought that the problem was resolved because 1 of my 2 vaults was synchronizing. The other one is my primary vault with a webdav sync parameter that I removed with last version tryouts....
When I tried to configure back this webdav sync, it tells me that the file or folder is unreachable.
In order to check, I synced the 2nd vault with apparent success then, removed the synchronization path, and tried to re-create the sync. It then failed telling me that the path/folder was unreachable...
So now, my two vaults are not able to sync...
Hi @hebusthib
We appreciate your providing feedback for our Enpass beta version. To thoroughly investigate the issue you are experiencing, kindly DM me the details of your WebDav demo account. I will then get it checked for you.
  • 2 weeks later...
The issue still persists... Also setting up new accounts, was not working. Strangely, alrady set up webdav accounts are working with some people...
Hello,
Glad to know I am not the only one with this behavior. I submitted some info on my WebDav config to help the team find the issue. We cross finger for next one.
BR
Ditto! Similar behavior for me as well.
Ich versuche schon den ganzen Tag meine WEBDAV URL zu synchronisieren!!
Einmal abgemeldet und es geht nicht mehr!
das nun schon wie ich hier lese seit zwei Monaten!
Wann kann ich endlich wieder diese App benutzen?
I've been trying to synchronize my WEBDAV URL all day!!
Once logged out and it won't work anymore!
As I have been reading here for two months now!
When can I finally use this app again?
Hi @all
We are aware of the issue some users are facing with syncing through the WebDav service after the recent update and we have identified the bug on our end. Our dedicated team is working on fixing it and soon a patch will be released which will address this issue. Thank you for your patience while we work on fixing this issue.
#SI-2802
  • 2 weeks later...
I’m getting similar errors on the Mac App Store version of the app: “Please authorize again using your WebDAV account.”
This needs to be fixed ASAP.
The Mac App Store version isn’t updated to 6.8.1 yet, so you should switch to the website download version since that supposedly fixes this issue.
The issue remain on Linux, ubuntu 20.04. After the latest update it worked for a day or two but now the issue is back. Enpass app is complaining that password is wrong and ask me to reenter but refuse to accept the correct password verified from other means. I'm using Enpass desktop app version 6.8.1 (1063). Enpass on android is fine.
Hi @svepass
Please DM me the details of your WebDav demo account and share its login id and password along with the URL. I will then get this investigated for you.
  • 3 weeks later...
I thought I had fixed this by updating to latest Nextcloud but my iPad is still complaining about the password being wrong.
Hi @David Jameson
Please DM me the details of your Enpass app version which you are using on your iPad and the WebDav demo account along with its login id, password and the URL. I will then get this checked for you.
Can't give you a demo account - the server is inside my LAN and only intended for use inside - it's not open to the outside world.
This problem is intermittent --- sometimes it can sync on my Mac and at other times I just get a sync error with a request for the password. And what's interesting is that when I enter the password again, it fails instantly as if it didn't even TRY to connect to the server.
I would add that the password for that server, albeit a nice randomly generated password, hasn't changed in 7 years since it's not accessible to the outside world.
