Enpass Mac OS Passkey issue
Hey since upgrading to Mac OS 15 Sequoia Enpass is not working anymore with Passkeys
If I am on a webpage where I have a passkey saved in Enpass and I want to login to the URL I just get the popup in the attached screenshot. I cannot choose enpass anymore to be used to fill out the passkey.
The only possibility now is to use my iPhone and then scan the barcode that is displayed on the Mac (safari and firefox) and then use my iPhone to pass the passkey to the browser.
Is there a workaround for this or a fix ??
Edited by Maclife
topic was not accurate anymore
Please ensure sure the "Manage Passkey" option is enabled in the Enpass extension settings.
Additionally, could you provide the following details:
  1. The URL of the website you're using
  2. The version of Enpass you're using, and whether it's the website or store version
  3. Are you experiencing this issue in all browsers or only in a specific one? Please specify the browser.
I have tried it on Mac OS in the latest Firefox and Safari versions.
Manage Passkeys is enabled
I am using the latest Enpass version from the Apple App Store.
What I realized in Mac OS system preferences it is not possible to switch these fields to Enpass. Which is possible on iOS. So maybe there is the issue.
I have tried to uninstall and reinstall Enpass already which did no changes at all
can confirm same on macos safari with latest OS, not being prompted for passkey any longer...only apple passkey works
Same problem here with
macos 14.7.1
Enpass 6.11.4 (Appstore)
Firefox 128.4.0esr + Enpass Extension 6.0.0.68b
Enpass is not listed as an option in System Settings > Passwords > Password Options > AutoFill from.
any updates on this topic. this is really annoying that u are not able to login to webpages with Passkeys.
23 hours ago, Tarun Singh Rawat said:
Please provide the below details:
  1. On which website(s) are you experiencing the issue?
  2. What is the creation date of the passkey you are using to sign in?
for instance this page: https://discourse.devontechnologies.com
passkey for this URL was created 1. August 2024
  • 1 month later...
  • 1 month later...
Following this because I too would like to use Passkeys from Enpass directly instead of Mac OS X's passkeys or iphone + scan.
  • 2 weeks later...
tried to use passkey on protonmail and it launches apple native passkey still even when extension is checked for passkey. is this resolved yet?
  • 1 month later...
@Tarun Singh Rawat
Could you please report on the progress? I'm currently loosing faith in Enpass, not being able to resolve such a problem in a timely manner.
It's obviously not an individual problem of a single user, but affects many (if not all) macos users.
Yea it is so annoying I have reported this issue over half a year ago and still no workaround fix or update
Our technical team has acknowledged the issue and is actively working on a solution. Fixing this bug may take some time, and the resolution will be included in the upcoming updates of the application.
We appreciate your patience and understanding
  • 2 weeks later...
thanks for acknowledging the issue.
I too am having the same problem. Frustrating because I can no longer use passkeys.
Wishing the technical team good speed for a fix!
  • 4 weeks later...
Has there been any progress on this, it would be nice to be able to store ones passkeys in enpass?
Edit:
Looks like the firefox extension will allow it.
Edited by caspergsht42
  • 3 weeks later...
  • 5 weeks later...
really sad that this topic is still not solved yet. It is been more than 7 months already
  • 2 months later...
Team, what is the status of this issue? We've been waiting since almost one year and this is a core feature for a password manager. When can we expect the Passkeys to work properly on macOS+Safari? Can we get an official team update ? I'm kind of surprised this bug is not a priority for the Enpass team, and not advertised on the Enpass's website homepage as a temporarily technical issue.
This bug is forcing people to switch to a different password manager as there are no workarounds. Switching browser just for the lack of this feature is not doable, and we're locked out of our accounts that are using passkeys. Why this was not prioritized yet? This is bad customer oriented development.
I actually have no confidence, that this issue will be resolved any more. That is especially bitter for a "premium product" with a recuring fee. One could expect better support from that.
As @meliot already pointed out, people are switching to different password managers - and so do I now.
I was a long-time enthusiast of this product but the lack of support, especially with this issue, killed my faith.
Farewell Enpass...
We absolutely understand that a solution on this has been delayed. Unfortunately, the problem isn't consistent and that makes it difficult for our team to reproduce and fix permanently.
Rest assured, we are pushing for a resolution on priority and will get back with something concrete at the soonest. We thank you for your understanding and trust in Enpass.
  • 3 months later...
I do have the same issue with this configuration:
  • Enpass 6.11.17 (2132)
  • macOS 15.6.1 (24G90)
  • Firefox 145.0.2 (aarch64)
  • Firefox Enpass extension 6.11.9.2
For example on https://id.kraken.com/sign-in:
Manage Passkeys is on:
Same happens with Safari 18.6 (20621.3.11.11.3).
On passkey.org it works though!
