macOS Golden Gate Beta - Extensions NOK
Extensions are NOK on macOS Golden Gate.
Enpass is not found. e.g. Brave, Edge Browser.
  • 2 weeks later...
i made a support ticket as it seems that no on from enpass is reacting here.
strange, it is EVERY time the same with a new macos and enpass team takes LONG to fix it
If i had no free lifetime license, i would have changed to any other password manager.
sad, but true.
  • 2 weeks later...
No change with the Enpass beta Version 6.12.4 (2624) from TestFlight released on 1 July.
Browsers still don't work. And once you remove them in the app they won't re-authenticate.
  • 2 weeks later...
macOS 27 beta 3 is out, and there's been no change for Enpass. Still broken with no new version in TestFlight to test.
Edited by Syd
  • 2 weeks later...
  • 3 weeks later...
Quality of life while using Enpass is really low without extension support. I'm really hesitating about switching to another password manager. Is there any update about this matter?
It will be ok when GoldenGate is released.
It was the same a year ago.
As i have the free version there is no real good alternatives.
Or does anyonr have one?
Apple Passwords is quite good now, this im using now till Enpass is OK again.
27.0 Beta 5 (26A5406e) is out and the current Enpass beta version 6.12.6 (2728) still doesn't work...
Any update?
A new Beta-Update, but NOK.
But really, how stupid can R&D be that they can't fix the problem?!?
Now it is really time to get rid of Enpass, sorry...
Now on selfhosted Vaultwarden.
Took me 30 Minutes...
Edited by longtom
  • 2 weeks later...
come on… This can‘t be so diffult as it is every year the same.
Also it seems that you are using an old way of Integration.
Vaultwarden is cool, no need for Enpass anymore.
  • 2 weeks later...
Adding my voice here. Just installed latest release of iOS 27 and not one browser extension is capable of connecting Enpass app on MacOS. This is brutal. It makes it near unusable. What is going on? Why is nobody on top of this? With AI tools today, this should be a 20 minute fix. Heck, I'd fix it on my own if I had access to the repo.
Testing Version 6.12.6 (2772) - seems to be working for Safari, Chrome, and Brave.
But not Firefox 155.0.1 (aarch64). I get Error 403
Edited by Syd
after upgrading my Macs (M5 Pro and M3 Pro) to macOS 27 Golden Gate, the Browser Extensions on Firefox and Edge are unable to connect to Enpass app. The Extension in Safari is working as expected. You can find the error messages attached.
Enpass Version 6.12.6 (2772) Mac AppStore
Firefox 155.0.1 - Extension 6.11.17.2
Edge 153.0.4234.32 - Extension 6.11.17
I would appreciate quick support.
Same problem,
even the new extension version for Edge 6.11.18 does not solve the problem.
2 hours ago, Tarun Singh Rawat said:
We have released a fix for this issue. Please update the Enpass app to version 6.12.6 and the Enpass Browser Extension to version 6.11.18.
Note: If you continue to experience the issue, please remove the Enpass Browser Extension from your browser and reinstall it.
Does not help for Microsoft Edge. Even removing the extension before does not help!
My Enpass version comes from Apple Store: 6.12.6 (2772)
I found a solution to get the extension for Edge under MacOS27 running:
Enpass -> Disable the option "Authorize browsers with verified code signatures only" in the section "Browser Authentification"
After disabling this, the integration works. But this is secure?
After the code has been requested again, you can re-enable the option
And thanks for finding :D - Now works my Firefox Extension again
@Tobi
I tried this, but this didn’t survive the next restart of my Mac and I had the same issue again.
