Posted
Adding a security PIN code does not work, and does nothing.
Menu = Tools\Settings\Security\Pin Code
  • Click Pin Code check mark.
  • Enter PIN.
  • Click OK.
  • Application returns to Settings/Security screen.
  • There is no check mark in Pin Code box.
  • Application behavior does not change, and does not behave like it uses a pin code.
Enpass v5.5.2
Posted
Hi @jakejohn
Sorry to hear about your trouble. Please share some more information so that we can take a closer look and check on this.
  • Have you observed the same problem of settings being not preserved with any other settings in Enpass?
  • Which Windows version are you using?
  • Are any changes in Enpass data being saved? Like marking/unmarking favorites, creating new items?
  • Are you using Enpass as a same user, who installed it in PC? Might me an issue related to permissions required to save changes on File system.
Thanks for your co-operation!
Posted
            Favorites are not saving.
            I just noticed the Security setting "Lock when system gets locked" is not saving too.
            Windows 7 x64
            New Items are not being saved.
            Yes, same user.
There is no indication from Enpass settings/data not saved.  This actually might be the bigger problem.
Thank you.
Posted
Hi @jakejohn
Thanks for writing back and sharing the details.
Please try these steps and let me know if your problem still persists.
  • Go to User Document Folder --> Open Enpass Folder --> Select walletx.db file --> Right-click on it and select Properties --> And check the Read-only option is enabled? if yes, please disable it and then try to set PIN in Enpass.
Also, please update the latest version(5.5.3) of Enpass.
Hope this helps!
