DeluxeAssi 0 Report post Posted April 20, 2020 (edited) Hi all, i am wondering if its possible to change the default vault in the MAC app? When i start Enpass under my Wife's Account, she always must type in the master password from my vault (thats the default vault) Thanks for your help, Peter Edited April 20, 2020 by DeluxeAssi Quote Share this post Link to post Share on other sites
Garima Singh 80 Report post Posted April 21, 2020 Hi @DeluxeAssi Welcome to the forum! I would like to share that the by default vault will always be primary vault only. You can manually select the vault in which you wish to make any changes. However, I have noted your suggestion. Thanks. Quote Share this post Link to post Share on other sites
Stefan Weber 0 Report post Posted May 4, 2020 Hello, got the same problem. By the way, much nicer it would be, to offer a selection to which vault you like to open when starting enpass. Last but not least I could create an backup from the default vault, but I was not able to import that backup in a fresh created vault vault. Did I do somethng wrong, or did I miss somethng? Any help how to do so? My plan was to create two new vaults inside the default vault and access them seperate. The default vault would stay nearly empty in this process. Thx Stef Quote Share this post Link to post Share on other sites
sixdas 2 Report post Posted May 4, 2020 (edited) Hello, I also join in your request, I had already done it more than a month ago (I attach link). It would be nice to manage vaults independently, so that if I want to create one for bank access and one for websites, I only unlock what I need and not all vaults. I think it's a smarter and safer way. Hopefully it will be evaluated by the development team and implemented. PS. for moderators, there is no place to see what you are working on, so that we don't always ask the same things, that maybe you are already working on them. Thanks Edited May 4, 2020 by sixdas Quote Share this post Link to post Share on other sites
Garima Singh 80 Report post Posted May 5, 2020 Hey @sixdas @Stefan Weber Thanks for using Enpass and writing to us. We really appreciate you for exploring the app and giving time in finding this valuable suggestion. The suggestion has been noted and forwarded to the development team for further consideration. 19 hours ago, Stefan Weber said: Last but not least I could create an backup from the default vault, but I was not able to import that backup in a fresh created vault vault. Did I do somethng wrong, or did I miss somethng? Any help how to do so? My plan was to create two new vaults inside the default vault and access them seperate. The default vault would stay nearly empty in this process. @Stefan Weber Please follow this method to restore the backup file of the vault you created and saved locally- Open Enpass> Go to ‘Enpass settings’ --> Tap on 'Vaults'--> Create a new vault by clicking on '+' --> Click on ‘Local storage’ under Backup file --> Select the location and folder of file(which you saved locally) --> Click on Continue --> Enter master password (same you using previously)--> Tap on 'Continue'. Thanks for the suggestion! Quote Share this post Link to post Share on other sites
Stefan Weber 0 Report post Posted May 12, 2020 (edited) Hi all, I played a bit with the vaults. There is one thing which is not as good as I expected and as it should be (from my point of view). Lets explain it: I like to use different vault for my wife and for myself. This also implies that I use different passwords for different vaults. This works, but both must knew the master password and with the master password you could lookup the passwords for all additional vaults. -- That's a big problem! This makes the extra password for any additional vault meaningless! Could you fix this? You got the possibility to store the vault passwords within the default vault (if you want), so there is no need for this functionality. Best regard and stay healthy Stef Edited May 12, 2020 by Stefan Weber Quote Share this post Link to post Share on other sites
sixdas 2 Report post Posted May 12, 2020 Yes it is also fundamental for me, I am waiting to make the exchange from lastpass, until they add this functionality we have asked for this functionality too, they have accepted the request, but I don't think they are working on it. Some of the staff could update us, maybe if there is a log on what you are working on, so that we don't always ask the same thing it would be fantastic thanks Quote Share this post Link to post Share on other sites
Pratyush Sharma 83 Report post Posted May 12, 2020 Hi @Stefan Weber & @sixdas, Sorry for the inconvenience caused to you. I have noted down your feedback and notified the concerned team for further consideration. Thanks for your co-operation. Quote Share this post Link to post Share on other sites
Stefan Weber 0 Report post Posted May 12, 2020 By the way, I forgot to mention, there is one other problem and I hope you may help me with it. All entries in additional vaults are accessable from the default vault, without asking for a password (even it is not stored in the default vault). Is there a way to force asking for a password of the additional vault when accessing an additional vault? Best Stef Quote Share this post Link to post Share on other sites
Pratyush Sharma 83 Report post Posted May 15, 2020 Hi @Stefan Weber, Thanks for writing in. Currently, there is no option available in the Enpass to force asking for a password when accessing other vaults. Thanks! Quote Share this post Link to post Share on other sites
