Nimber
How to enable tap to click function in the Enpass
Hi, I am a new user to Mac and I set tap to click function in my new MacBook. However, I find out that tap to click function is not working in Enpass. I have to click the button rather than simply tap it. How can I enable it for Enpass? Thank you!
Share this post
Link to post
Share on other sites
@Nimber
Welcome to Enpass forums. Thanks for writing in. Could you help us with the Enpass version you're using? You'll find it under Menu(Hamburger button) -> Help -> About. Also, let us know the Mac model and the OS version.
Thanks.
Share this post
Link to post
2 hours ago, Kashish said:
@Nimber
Thanks.
Thank you very much for your reply! My Enpass version is 6.4.2 (668). Mac model is MacBookPro16,2. macOS version is 10.15.5.
Share this post
Link to post
Hi @Nimber
Unfortunately, I am not able to understand the issue you are having with Enpass. Please let us know so that I can assist you better.
Thanks.
Share this post
Link to post
1 hour ago, Garima Singh said:
Hi @Nimber
Thanks.
The phenomenon is like when I try to click on a button use trackpad on the panel of Enpass in Safari, I have to click it to make it response rather than just tap it. When I tap it, the button will be selected but nothing will happen unless I click it. However, in the system setup, I have already checked "Tap to Click" option.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
