July 4, 20169 yr I get Enpass Connection error advising to enable browser extension in preferences. I followed the instruction and Enpass still won't work. Disabled/re-enabled the extension, reinstalled the extension, same problem. Enpass works fine on same PC with Safari. Version: 38.0.2220.31 - Opera is up to date Update stream: Stable System: Mac OS X 10.11.5 64-bit
July 5, 20169 yr Hi @tb, Sorry to hear about the trouble. Please let us know some more details like Antivirus/Firewall/third party network security/ any security related Extension or Proxy are you using, so that we can investigate where the problem could be.
July 5, 20169 yr Author I don't have any antivirus or 3rd party firewall. I have Trusteer enabled on Safari Browser but not Opera. Fault is only with Opera. Have Surf Easy VPN but it is disabled in Opera
July 5, 20169 yr Author If I uncheck Verify Browsers in Enpass preferences then Enpass functions normal. What are the risks leaving Verify unchecked?
July 7, 20169 yr Hi @tb, Its great to know that for the time being you are able to work with Opera extensions by turning off code signature. But we don’t recommended to use Enpass by disabling the code signature verification. As mentioned here under communication section, Enpass App validates authenticity of both extension and Browser before making any connection and serving data for autofilling. So if you turn off the code signature verification, you can bypass the Browser checking and set your foot into autofilling in Opera Browser. To avoid any security risks associated with turning off the code signature verification, please make sure that you download the browser from the legitimate source and double check the authenticity of any extension you install. As soon as we find any solution, we will update you and would be very grateful to you in helping us by checking the suggested solution as till now you’re the only user facing this issue. Regards
July 7, 20169 yr Author I downloaded it from Opera. Try it and see if you can find the problem http://www.opera.com/computer My OS is Max OS X. Version 10.11.5
July 8, 20169 yr Hi @tb, I have just downloaded the Opera browser from the link you have provided, and its working fine with the same configuration of System as you have.
July 18, 20169 yr I'm having the same problem interestingly, the beta version of Opera didn't work ( it worked by unchecking the code signature box) while the stable version of opera worked out of the box. Edited July 18, 20169 yr by Xiaoken
January 10, 20179 yr Same Problem here: Versionsinformation Version: 42.0.2393.94 - Opera ist auf dem neuesten Stand Update-Stream: Stable Betriebssystem: Mac OS X 10.11.6 64-bit
January 11, 20179 yr Hi @gbt, Sorry to hear that. To investigate it further, please run the following command in terminal and share the output via email at support@enpass.io mentioning a link to this discussion and we will take it further. lsof -i:10391 Where 10391 is the port number. If there is no output (blank), please try with other port numbers between 10391 to 10395. Also please let me know are you facing the same problem with other browsers ( Chrome/ Safari/ Firefox) too.
January 11, 20179 yr The output is the same as above. Tested with Opera and Google Chrome. "Enpass Connection Error." Only Safari works perfectly.
