December 9, 20214 yr I have added the URL to the block list. It just doesn't work, The extension will still appear in the page. Enpass and extension are the latest versions, and so is Chrome browser.
December 9, 20214 yr Author This extension will cause the website not work properly, so I can only add it to the block list, unfortunately, the block list does not work either.
December 10, 20214 yr @mark chang, you need to use wildcard url for the particular websites. Please add this URL in Block list menu: https://www.dianxiaomi.com/* Hope this helps! Edited December 10, 20214 yr by Samuela
December 10, 20214 yr Hi @mark chang, Welcome to the Enpass Community. As suggested by @Samuela, If you want to block an entire website domain then Wildcard URL can be used, to do so please append an asterisk at the end of the URL for example, https://www.dianxiaomi.com/*. (This will block the Inline option over the domain whenever opened) However, if you do not wish to block a complete domain and just a single webpage then add the whole URL i.e "https://www.dianxiaomi.com/index.html" into the Inline Autofill Popup Menu Blocklist. (This will only block the Inline option over a particular webpage, as blocklist is URL specific not domain specific)
