We’re on Reddit now πŸŽ‰ πŸŽ‰ πŸ’¬ Come and join us there!! Γ—
Posted
Hello, I'm glad to switch to Enpass. Everything works perfect. But as for while Windows 10/11 comes with UI improvements. So unfortunatelly system tray icon doesn't fit Windows UI. If you look like Onedrive, dropbox, wifi, speaker etc iccons they looks right for Windows 10/11.
Posted
Hi @INTRASERVER
Thanks for the suggestion.
Happy to have you on board, you made the right choice! I have also forwarded your comment as feedback to the dedicated development team so they may improve upon it in the future Enpass versions. We appreciate your patience and support in the meantime!
#SI-2563
Posted
Totally off-topic, but what are those applets called showing your network\cpu\mem-stats in system tray?
Posted
The version available on Microsoft Store uses a modernized icon, should you be able to use that.Β
Posted
But please make that an optional choice! Although I'm using Windows 11, I would prefer the colored icon if I had the choice. ;)Β
  • Like 1
Create an account
Register a new account
Sign in
Sign In Now
