Posted
I've set up Touch ID in the app. I would like to set it to always ask for a password on first startup and only then use Touch ID. Is there a way to do this?
Posted
Yes, the behavior you're describing is already in Enpass. Whenever you enable touch ID for unlock application. Enpass is designed to prioritize security, especially when it comes to initial logins after restarting the app, your device, or after updating it. This ensures an extra layer of protection by asking for the master password before allowing access to sensitive information, even if Touch ID is enabled.
Posted (edited)
Adding to this question...  I don't agree that requiring the password on initial logins after restarting the app, the device or after updating it adds security if touch ID is turned on.  The OS takes care of that when your OS password is required then.  It's annoying and all other apps that support touch ID do not behave that way.
i have to log into another app, using touch ID, copy the master password, then paste it.  Or I could type it, but it's long and complicated.  This subjects my master password to key loggers or having my master password in the clipboard.
The fewer times I have to enter my master password, the more secure it is.
Edited by rwright
Posted
Thank you for sharing your perspective on the login behavior in Enpass. We appreciate your feedback and understand your concerns regarding the frequency of entering the master password, especially when Touch ID is enabled.
We constantly strive to balance security with user convenience in Enpass. Your input is valuable to us as we consider improvements to the login process. I will ensure to pass your feedback along to our development team for further consideration.
Create an account
Register a new account
Sign in
Sign In Now
