Orson Wang Posted October 11, 2016 Report Posted October 11, 2016 Hi There: I am wondering if this can be fixed or I should not put Dock at right. The extension on macOS will always stick to rightmost of screen. When you using system Dock on the right. I cannot click the rightmost button like "copy password", "info", which is very annoying. Can you add code to detect the rightmost of working viewport(Desktop/host application like chrome, firefox) instead of rightmost of screen?
Anshu kumar Posted October 12, 2016 Report Posted October 12, 2016 Hi @Orson Wang, Thanks for reporting this issue and I'm sorry for the inconvenience caused you. I have noted down this issue in bug tracker and forwarded to dev team, so they can try to fix this issue asap. Till then I request you to please bear with us.
Victor Chu Posted November 24, 2016 Report Posted November 24, 2016 (edited) Hello, even more, using 2 displays (retina + non-retina external) and launching from the menu bar - enpass window appears in the lower right corner of the external display and top right corner of the retina one (splitted) and right side of the window is not visible. This make it useless. i'd prefer this window to be opened right under the menu bar. This is how in looks from the screen shot, but really it is split on 2 screens. Edited November 24, 2016 by Victor Chu
Victor Chu Posted November 24, 2016 Report Posted November 24, 2016 This is much better shot of what really happens
Anshu kumar Posted November 24, 2016 Report Posted November 24, 2016 Hi @Victor Chu Sorry to hear about your trouble. Could you please try the latest Beta version and see if it fixes this problem? Please keep me posted. Cheers!
