December 10, 20214 yr I'm using Vivaldi browser 5.0.2497.28 (Stable channel) (64-Bit) and Enpass extension 6.7.4. The new inline autofill feature is great, but it seems that own website icons are ignored there. I disabled the download of website icons, so there are only default icons for websites. I collected some icons and put them into the login entries. As an example, these website icons are shown in Enpass and in the Enpass-Dock. But in the inline autofill popup still the default icons are shown. Is this a known bug? It would be great if you would fix it.
December 13, 20214 yr Hi @DenalB, Thank you for reaching out to us. Please share the following details so that I can get this issue tested for your from our concerned team. On which device (along with OS version) are you using Enpass? Which Enpass version are you using? (Is it a Store or Website version)? Are you facing the same problem with other browsers too? On which Web pages you are getting this issue?
December 14, 20214 yr Author Hey @Gulshan Dogra, Thanks for your help. Here are answers to your questions. 21 hours ago, Gulshan Dogra said: On which device (along with OS version) are you using Enpass? Windows 11 Pro 21H2 Build 22000.348 21 hours ago, Gulshan Dogra said: Which Enpass version are you using? (Is it a Store or Website version)? I'm using Website version 6.7.4 (933) of Enpass. 21 hours ago, Gulshan Dogra said: Are you facing the same problem with other browsers too? Yes. There is the same issue in Vivaldi browser 5.0.2497.28 (Stable channel) (64-Bit) and Microsoft Edge browser 96.0.1054.53 (Official Build) (64-Bit). I think it doesn't depend on the browser. 21 hours ago, Gulshan Dogra said: On which Web pages you are getting this issue? On any Webpage. It doesn't matter. You only have to disable the Enpass setting "Use Website Icons" and manually select icons for your entries. These are the first 10 Website entries in my Enpass vault. I chose own icons here. https://abload.dehttps://www.acdsee.comhttps://www.acronis.comhttps://www.activision.comhttps://www.adac.dehttps://www.adobe.comhttps://forum.affinity.serif.comhttps://affinity.serif.com/de/store/https://www.alcohol-soft.comhttps://www.aldifotos.de If you try to select your credentials with the help of the infield autofill, you'll never see your own chosen icons. As you can see compared to the screenshot from my vault, none of these icons are my chosen ones. Only your default icons are shown, which your devs had set for some specific Websites like "Acronis", "ADAC" or "Adobe". I hope I could help here.
December 28, 20214 yr Same thing happens to me. I'm using enpass browser extension 6.7.4 on chrome and enpass website version 6.7.4 (933) on windows 10. I hope you can fix this Thank you!
December 28, 20214 yr Hi @vidario and @DenalB Thank you for contacting Enpass. I would like to share that our team is aware about this issue and our team is working on it, it will be fixed in the future updates of Enpass. Your patience is highly appreaciated. Cheers! #SI-2507
January 31, 20224 yr In some cases, the Inline Autofill Popup displays the incorrect icon for the Item being suggested for autofill. Illustrated screenshot attached. This item was created in Enpass before the custom icons feature was introduced, and the icon shown in the Inline Autofill Popup is the icon I originally chose for this Item — 3 years ago. But once custom icons could be created, I copied the logo for the site and added it to the item. I have changed to "Use Website Icon," but I get an error saying the icon isn't available from the site (the site has no favicon). I have deleted and re-added the custom icon several times, but it doesn't help. I have created a new custom icon and applied that, but it doesn't help. I have created a new Item for this site, saved it first with a generic icon, then Edited the item and applied the custom icon, and the problem persists. I have created a new Item for this site, and added the custom icon immediately, and the problem persists. I haven't noticed this problem with any other Items in Enpass — even with other sites that have no Favicon of their own. Since it seems to be specific to this site, FYI, the site is https://www.yourwyoblue.com/home/. I've created Enpass items with nonsense logins for this site, and the problem persists, so if it's somehow site specific, it should be reproducible without having an actual account at the site.
January 31, 20224 yr Hi @100 Watt Walrus For quick troubleshooting purposes, please uninstall the Enpass Extension from your browser, and then disable the Extension from your Enpass app by going to Enpass Settings -> Browser -> Extension -> Untick Enable Browser Extensions. Now, reinstall Enpass Extension for your browser from here and under the Enpass app settings, enable the Browser Extension. If the issue persists, then I'll require some additional information. Please share the version of the Enpass app (Website or Store), OS, browser and Enpass extension you are using and I'll get this checked for you.
January 31, 20224 yr Author Hi @100 Watt Walrus! It sounds like it could be the same issue as I reported here: But it should be fixed with an upcoming release of the extension, stated here: Or do I missed something from your post, @100 Watt Walrus? Edited January 31, 20224 yr by DenalB
February 4, 20224 yr @Abhishek Dewan Enpass Beta 6.7.4 (951) — macOS 11.6.1 Have uninstalled/reinstalled extension as instructed on my main browser (Brave), and it made no difference. The same Enpass item has the same problem across Brave, Chrome, Firefox and Safari. Edited February 4, 20224 yr by 100 Watt Walrus
February 4, 20224 yr On 1/31/2022 at 4:50 AM, DenalB said: It sounds like it could be the same issue as I reported here: Seems to be the same kind of issue, but my case with just one Item (that I've seen so far anyway).
May 29, 20224 yr Dear support, As seen in the following capture, password "qnap admin" is configured with a custom icon: It works fine everywhere, but not in the inline autofill: It shows 9gag, because for testing purposes I selected 9gag (first one in the list of predefined icons) before reverting to the custom icon. Let me know if you need anything more. It should be easy enough to reproduce, hopefully to fix as well Enpass version: 6.8.1 Edge extension: 6.7.5
May 29, 20224 yr Doh... this one should be in the autofill section. I created it wrong - my bad. Can a mod please move it to where it should?
May 31, 20224 yr Hey @FuN_KeY, Thanks for reaching out to us and sharing the details. I would like to share that we are aware of this issue and our backend team is working on it towards its fix. It will be fixed in the future updates of Enpass. In the meantime, we appreciate your patience and support in advance. #SI-2888 #SI-2507
October 25, 20233 yr Hello @Gulshan Dogra The problem is still present on my end. Had the team found the time to work on that?
