February 10, 20233 yr Hi Enpass Team, First I want to say thank you: For the last couple of years, enpass crashed quite often on my notebook and since a few month it seems to be very stable. Thanks for that! Now to my little issue: When I activate autostart on windows start, every time enpass launches, it also launches a console window, that quickly after that closes. This by itself is no issue. But this also launches my Windows Terminal app, which after than stays open. As soon as I disable enpass autostart, this does not happen anymore. BTW this also happens when I don't auto start enpass but then manually open enpass. So it seems that this is an issue with enpass altogether and not the autostart function. It's very annoying that my windows terminal opens every time I restart windows. Can you please look into that and maybe avoid the opening of the terminal window altogether? Information: Enpass 6.8.5 (1238) Windows 11 Pro 22H2 (22623.1255) Thanks! Regards, Florian
February 13, 20233 yr Hi @Zoker Thank you for sharing the details related to this case. I'm discussing it with our dedicated team and will get back to you soon with an update. Your patience in the meantime is appreciated. #SI-3274
February 14, 20233 yr Hi @Zoker We were able to reproduce the bug on our end, due to which this issue is occurring, and a fix will be available for this concern in the future Enpass update. Kindly bear with us until then, and your cooperation in the meantime is appreciated.
March 28, 20233 yr I've installed Enpass on different systems (Windows 10, Windows 11 and Mac OS). Only Windows 11 (22H2) I noticed a peculiar behaviour when starting the software: Before the actual Enpass screen appears a windows command window very briefly appears in the background. After that Enpass starts normally. I was able to record the background processes running for a fraction of a second (see attached image). Is this behaviour intentional and why does it happen only on Windows 11?
April 11, 20233 yr It's been bugging me for months and I finally took the time to figure out which program was causing this. It was enpass windows store app. When I log on the command prompt flashes briefly. Disabling it in the task managers startup apps tab disables my ability to input any key strokes into the windows 11 search bar. How do I get it to stop flashing the prompt while still running at startup?
April 28, 20233 yr Hi, I'm curious what does Enpass do whenever I load the program it opens a command prompt with path. C:\Program Files\WindowsAP as shown on the screenshot below. It does not seem to run any batch file or program file.
April 28, 20233 yr 2 hours ago, elitesonny said: Hi, I'm curious what does Enpass do whenever I load the program it opens a command prompt with path. C:\Program Files\WindowsAP as shown on the screenshot below. It does not seem to run any batch file or program file. I was able to fix this by installing the non-microsoft store version of enpass.
October 19, 20233 yr I am a bit annoyed about the terminal popping up everytime when I start Windows. What is the reason for this?
October 23, 20233 yr It's irritating seeing that terminal flashing on every system start-up. Instead of relying solely on command prompt, the Enpass team could look into using a .vbs script to make launching process more silent and inline with other start-up applications.
October 30, 20233 yr Hello. I don't know if there's an open issue tracker for Enpass, so let's post here: When Enpass Desktop autostarts at login, at least on Windows and Linux, it opens its main window and then hides it. Apparently, the window just disappear when it gain focus, what sometimes happens immediately (and then the window just flashes) but sometimes happens just after the window is clicked on. It has been this way for years now and in reality is just a minor annoyance. However, I never understood why it happens and it is the only well polished application for which I observe this strange behaviour. Is this a bug or a feature?
November 13, 20232 yr On 2/14/2023 at 5:34 PM, Abhishek Dewan said: Hi @Zoker We were able to reproduce the bug on our end, due to which this issue is occurring, and a fix will be available for this concern in the future Enpass update. Kindly bear with us until then, and your cooperation in the meantime is appreciated. Hi. It is november now. 9 months of so many terminal apps open and have to manually close for no reason. On top of that, for me, it opens the WSL Ubuntu. I am on latest version and it is still not fixed. When can we expect a fix for this?
August 12, 20242 yr I remember having opened a thread about this issue back in 2021 (here). It is definitely disappointing to see that this has not been adressed yet. Seeing a CMD window pop up and disappear is extremely jarring and makes me worry that there might be some kind of malware running on my computer..
October 22, 20251 yr Unfortunately, this issue has been around for years, and nothing seems to have been done by the @Enpass Dev Team. Could you please clarify the current status? Why does Enpass initiate a Terminal window on startup (this also occurs on Linux)? Is there any way to prevent this behavior? It would be great to know whether the Enpass team plans to disable this in upcoming releases. Like many others here, I find this behavior quite irritating and unnecessary. Thank you!
March 13Mar 13 Unfortunately, this and many other irritation in the Enpass app are of low priority to the Enpass team. They're solely focused on enterprise, forgetting it's us power users that introduced them to enterprises in the first place...
April 30Apr 30 Hello,I have found a workaround to prevent Terminal pop-up when using the Microsoft Store version.Right click --> New --> ShortcutIn "Type the location of item:", enter the below:enpass://Name of the shortcut can be anything, usually Enpass Password Manager.Done!!! Now the CLI window won't pop-up. As an added benefit, Enpass window also launches quicker!You can also use enpass:// in AutoHotkey or disable Enpass's built-in startup and Win + R --> shell:startup & move shortcut there to have it auto-start at boot without the CLI window. Edited April 30Apr 30 by downloaderfan
May 22May 22 Thank you for your understanding. We apologize for the inconvenience, and our team is investigating the issue. We’ll keep you posted.
