Enpass freezes when I try to restore a vault from OneDrive
Recently I upgraded to Mac OS Big Sur, so I re-installed all my applications after it, BTW I did a clean installation of the OS, not an upgrade. Besides that I was able to install and restore a vault saved at Google Drive, then it was the turn of my job vault, which is tired in Microsoft OneDrive, but when I configure it Enpass just freezes, no error message, no nothing.
I have the MacApp Store version of Enpass installed (6.5.2) with my license configured on it.
I hope you can help me to solve this issue.
Best regards,
Hi @Oscar A. Mata T.
We need a little input from you, so please let us know are you using any special characters in the name of Secondary vault. If Yes, try to give a name without special characters and share your findings.
Thanks for your co-operation.
  • 2 weeks later...
¿There is a proper way to ask for support?
It looks like forums aren't the right way. No solution given to users using forum.
Regards,
Hey @Oscar A. Mata T.
We understand your concern and are extremely sorry for the trouble you have been facing from a long time. Please try the below workaround and let us know if this is helpful:
  1. Create a new empty vault with same password.
  2. Now setup sync of this empty vault with the same one-drive account.
  • 2 months later...
