Posted
Hi everyone!
Every other day, I get a notification from "Android System" which says:
Check access settings
Enpass can view and control your screen. Tap to review.
When I tap the notification, it will take me to the Accessibility -> Enpass settings. "Use Enpass" of course is enabled, as I want to make use of this feature.
How do I get rid of this?
Thanks
Posted (edited)
Similar issue.
I have to enable "Autofill Using Accessibility" every time Enpass app requires master password.
Also, Enpass does not show up for saving or filling fields in some apps. Is there any way to force it to happen?
Enpass version: 6.7.1.572
Android 11, Security Update March 2022
Samsung A50, One UI version 3.1
Edited by Sonic
Posted
Hi Manish ..
I got autofill working after rebooting/swapping back and forth a few times.
Apps are linked now.
Enabling the "Autofill using Accessibility" every time is a drag though.
Need to do it whenever Enpass requires password during launch.
In the "Settings->Accessibility->Installed Services", Enpass gets disabled and hence the problem.
  • Like 1
  • 3 weeks later...
Posted
Update:
Sorry for the delay.
Got the "Autofill using Accessibility" option working. Took some experimenting, but excluded Enpass from apps slated for sleep and it's now functioning as desired.
Got to hand it to you team, it's a great app. The Desktop version works flawlessly too.
  • Like 1
Create an account
Register a new account
Sign in
Sign In Now
