eaglef Posted February 18, 2023 Report Posted February 18, 2023 I'm using Enpass on many devices (Windows, Linux, Android) without issues. The Android App also works Chrome Books, BUT with problems: I cannot use the fingerprint reader of the Chrome Book to login to Enpass. Is there a way to use the Fingerprint reader of the Chrome book within an Android app? After a short time (about 1 minute) I'm getting locked out from Enpass, if Enpass beeing in backgroud. No matter the security settings of Enpass (lock time is set to hours!) I even cannot use my PIN to enter,I have to use the password. I think both ptoblems are connected with the architecture of chrome os, but is there a workaround? Kind Regards, Frank
Abhishek Dewan Posted February 20, 2023 Report Posted February 20, 2023 Hi @eaglef Welcome to the Enpass Forums. Our development team is aware of the demand for fingerprint reader support on Chromebook. This feature request may be included in future Enpass releases even though we have not yet received any specific version updates. Regarding Enpass getting locked and requiring master password instead of PIN, I would like to share that Enpass requires Master Password in the following scenarios (even if the PIN is enabled): · When the app is closed manually. · The device is rebooted. · When too many apps are active in the device background (in this case OS automatically kills some apps to claim memory). · Similarly, if a user is running the device in power saver mode, or has installed a third-party app that kills background applications. Please check the settings of your device once and look for any third-party applications which may be interfering in this case. #SI-2298
niranjanayar Posted February 22, 2023 Report Posted February 22, 2023 (edited) Enpass extension - Chromebook - Enpass. Enpass connects and autofill in Chrome browser using the Enpass extension. You can install it from the Chrome Web Store. This page will be auto closed after the connection is established in next step. cinema hd v2.5.0 Edited February 22, 2023 by niranjanayar
Johnmelody Posted January 12, 2024 Report Posted January 12, 2024 I've really run into this sort of thing with Chrome Books. But with the experts from personal statement services it was possible to fix the shortcomings of the Chrome Book fingerprint scanner for logging into Enpass. The guys loaded it through the bios, which helped bypass the program. In your case, you need to try.
Amandeep Kumar Posted February 19, 2024 Report Posted February 19, 2024 I've reported this issue to the Enpass technical team. They are currently investigating it, and I will reach out to you with updates as soon as I receive them. Thank you for your patience, and feel free to provide any additional feedback. #SI-3561
Create an account
Register a new accountSign in
Sign In Now
