Mandrake 1 Report post Posted October 25, 2016 (edited) Hi I installed Enpass on a PC with Win7 32Bit. OKThe program and the extensions of browsers work.I then installed the program on my main computer 64Bits with Windows 7. The program installs but then I different problems.Browser extensions do not work. Nothing happens.When Enpass is reduced, it is impossible to get it back.Note: I use Firefox 64Bits release.Do you have an idea ? I tried on another PC 64 bit and I have not had any problems. I do not understand what is blocking? Edited October 25, 2016 by Mandrake Share this post Link to post Share on other sites
Anshu kumar 314 Report post Posted October 26, 2016 Hi @Mandrake Sorry to hear about your trouble. To diagnose this issue I want a little help from your side. Please follow these steps: Step 1: Log into Enpass --> Go to Tools --> Settings --> General --> Enable Minimize App to System Tray. Now click (Single click) on Enpass icon in the System tray and check whether it display Enpass mini window. Step 2: Open Task Manager --> Tap Details --> And check Enpass.exe and Enpasshelper.exe is there? And also please provide some more details like Enpass version, Antivirus /Firewall/third party network security/ any security related Extension or Proxy are you using. Share this post Link to post Share on other sites
Mandrake 1 Report post Posted October 27, 2016 Hi Anshu I found the culprit.The Enpass program is not recognized by Comodo, its HIPS blocks the process.There I had to change the rules.I want to know why "Enpass.exe" and "Enpass helper" need to connect to the outside. I have my firewall alerts.If I block "Enpass helper" Enpass does not. Share this post Link to post Share on other sites
Vinod Kumar 110 Report post Posted October 27, 2016 Hi @Mandrake, Enpass.exe runs a websocket on localhost loopback (not accessible to other machines ) to communicate with EnpassHelper.exe and browser extension. If you block opening of websocket in your firewall, browser extensions are not going to work. Adding a rule in firewall to allow Enpass open a outbound port on localhost will sort out things. Please see more details here about working and security of browser extensions here. Share this post Link to post Share on other sites
