August 14, 20233 yr Hello, I bought this app some time back and have one vault saved on Google Drive. Whether I downloaded the app from the app store or the website, I consistently face an issue: the app freezes upon reopening. The problem doesn't arise if the app is not opened at all, but if it's already running and I use my fingerprint to log in, it becomes unresponsive. As a workaround, I deactivated the automatic check for new versions, which alleviated the issue slightly, but the problem persists intermittently. I also tried disabling the browser popup as suggested on the forums, but to no avail. Interestingly, when I use the app on another computer with Mac OS Ventura on an Intel chip, and on Windows as well, it operates smoothly. I'd appreciate any assistance to continue using this app without hitches. Edited August 14, 20233 yr by Shlomi
August 16, 20233 yr Hi @Shlomi For troubleshooting purposes, please create a manual backup of your Enpass data and then reinstall the app. If the issue persists, kindly share the below details and I will get this checked for you - The version of the Enpass app, OS, Enpass Extension and browser you are using. Does the Enpass app freeze after a certain action? Like opening a webpage, editing an Item, etc, or is it completely random? The total number Items, vaults and attachments you have saved in the Enpass app.
August 18, 20233 yr Author Hello 1. Enpass version is 6.9.0, the operating system is Macos Ventura 13.4 <acbook Pro M2 chip, the os is chrome (i am not using extensions for passwords) 2. The app freezes if i do not totally quit it, but rather open it again, authenticating using the finger print. (To fix this i force quite and login using the password, and that is also sometimes does not help) 3. I have around 180 items, i have 1 vault on google drive, no attachments. I have just granted full disk access to Enpass (made a quick 1 test and it did not freeze, need to check again in an hour after system sleeps and i reactivate the app again from sleep), might it be having issues updating local copy when reactivated? On my intel based macos ventura i do not have full disk access and it works fine thou. I will post here if it helped, but would love to know if others with M2 are having the same issues. Regards, Shlomi Edited August 18, 20233 yr by Shlomi
August 18, 20233 yr Hi @Shlomi I appreciate you providing me with the latest information about this matter. Should you encounter this issue again, kindly update this same forum, and I'll be more than glad to conduct further investigation for you.
August 18, 20233 yr 10 hours ago, Shlomi said: ...would love to know if others with M2 are having the same issues. Just had a quick look Shlomi and neither my Intel Mac mini nor my M2 Pro Mac mini have Full Disk Access enabled for Enpass. Both machines are running Venture 13.5.1 and Enpass 6.9.0 (Mac App Store version).
August 19, 20233 yr Author Hi As it turned out this did not fix the issue, i am at a loss here, Enpass is not working properly only on this M2 Chip Macos Ventura computer. Is there an option to turn on the logs so i can send them?
August 21, 20233 yr Hi @Shlomi @Rootbeer I've escalated this concern to our specialized team, and they are actively addressing the issue on your behalf. Once I gather additional information regarding this issue, I will promptly provide an update on this forum. Your patience until that time is greatly appreciated. #SI-3446
August 29, 20233 yr Hi @Shlomi @Rootbeer Please perform a force quit of the application if it becomes unresponsive. This action will trigger the creation of a crash report that you can subsequently share with us.
September 3, 20233 yr Author Where will I find this crash report? I have changed settings to keep enpass active all the time (not a good practice) so i will not get it frozen. There is no logs or enable logs in advanced settings. Another weird thing happening sometimes, tags are being removed from certain records, mainly after a freeze, i need to reapply them all over again.
September 4, 20233 yr Author Hi @Abhishek Dewan @Rootbeer I just found out that if i do not use the pin or the finger to unlock but type the password each time it lock, it is working ok. Still, i am waiting for the explanation how to create a crash report Thanks in advance Shlomi Edited September 4, 20233 yr by Shlomi
September 4, 20233 yr Hi @Shlomi Allow the Enpass app to become unresponsive. Once it does, perform a force quit on the application . You should then see the crash report which you can share with us. In regard to the issue of tags disappearing, our development team is actively addressing this bug and working on a resolution. To stay updated on our progress and receive notifications when we post updates about the fix, you can follow the forum linked below -
September 5, 20233 yr Author Hi @Abhishek Dewan I tried to do exactly like described below but it did not help I just noticed that if i unlock with the Touch and instead of going to an item, i am opening the settings at first, then closing it and choosing an item it is working fine. So i unlock the app with my finger, i go and press the cog wheel, close it and then i browse my tags, seems to work without being stuck. Also I noticed that it does not happen when i use the password instead of the PIN or the Touch, if I unlock the enpass with the master password then i can browse my tags freely, hope it helps to pinpoint the issue further. There was a setting of creating crash logs in old versions, it is removed now, so I do not see how i can share a crash report. It does not being created at all not when i force quit from the dock or from the "Activity Manager" process section Regards, Shlomi
September 5, 20233 yr Hi @Shlomi Thank you for sharing the feedback with us. As we investigate the comments and attempt to replicate the issue on our side, please consider the following steps to see if the crash report becomes visible - Please check and ensure that you have install the Enpass Store version- 6.9.0 (1466). If not, kindly create a manual backup of your Enpass data, then install this version and restore the data from the backup file. Allow the Enpass app to become unresponsive. Once it does, perform a force quit on the application Now go to macOS Library>Logs>DiagnosticsRepors>--------.ips Share the Crash file (Feel free to DM me the file) Note - There is another way to check for the crash report: Open Console app in Mac --> Process Name Go to Crash reports under reports section --> Enpass-->Reveal in Finder
September 7, 20233 yr Author No crash reports are being generated, I am guessing that it goes into some infinite loop, having a sort of a race condition in the code. So when it is forced quit, it still somehow closed gracefully. Might be a good idea to give an option to disable the auto sync when activating the app, and letting the user do it manually if he/she wants to. We are not adding passwords every minute, so this auto sync on activation is an overkill
September 7, 20233 yr Hi @Shlomi Thank you for your feedback and trying the steps I shared. I've forwarded all the information to our dedicated team for their investigation. Once I receive further details on this matter, I will make sure to keep you updated.
September 11, 20233 yr Similar issue here, Enpass worked for years now but since the last update on my MBP M1 it keeps freezing - very annoying. Ventura 13.5 / Enpass 6.9.0 The same is true for the Chrome Browser Extension that won't open afterwards. Edited September 11, 20233 yr by janosch
September 11, 20233 yr Similar issue here. Brand new MacBook Pro, Ventura 13.5.2 / Enpass 6.9.0 Open, log in (using password) and before I can click anything it beachball/hangs. Both opening from the taskbar icon or the dock breaks. Running on old computer fine (MBP w/Intel running same versions)
October 2, 20233 yr Similar issue here. The problem started when I upgraded to latest version of Enpass. It was working fine before on an older version of Enpass (although not sure what this was now), up until the point I upgraded Enpass. I am currently on MacBook Pro M1, Ventura 13.5.2 / Enpass 6.9.1 (1512). I'm having the exact experience Shlomi was having. Works fine if opening for the first time, but if I reopen after it has locked I get the spinning beachball of death and have to force quit the app. (Note: seems to work fine on a separate Macbook Air M2, Sonoma 14.0 / Enpass 6.9.1 (1512), eg. exactly the same version of Enpass. Unfortunately I can't upgrade the M1 Macbook Pro to Sonoma!)
October 2, 20233 yr On 9/7/2023 at 9:03 AM, Shlomi said: We are not adding passwords every minute, so this auto sync on activation is an overkill I suspect this is useful for preventing conflicts when multiple devices are used.
January 16, 20242 yr Similar issue here. I'm having the exact experience Shlomi and kefa was having. Works fine if opening for the first time, but if I reopen after it has locked I get the spinning beachball of death and have to force quit the app. I repeat reopening enpass three or four times. Then enpass works fine again. So sometimes it works sometimes not. am currently on iMac M1, Ventura 13.6.3 / Enpass 6.9.3 from Apple Store. Are there any solutions?
January 23, 20242 yr I got an update from the Enpass technical team, and I would like to share the below steps: If Enpass shows the crash dialog box "Enpass Crash Reporter" and gives an option to submit the crash report, that is fine. But if not, then the crash report can be found in the system. Here are the steps to locate the crash report: 1. Open Console app. 2. Select 'Crash Reports' from the left sidebar. 3. Check for reports generated by the Enpass app. 4. Select the crash report, right-click, and choose "Reveal in Finder." 5. You will see the .ips file. Please share that file with us. Note: This request is for all the reporting users to please try this on an Enpass macOS Store version like - 6.9.3 (1592).
January 28, 20242 yr Author @Mohit Thapa @wowa @kefa @Camwyn @janosch Do not know if this is related, i have the version 6.9.2 (1564) And since i upgraded my M2 Mac to Sonoma 14.2.1 (23C71) problem is not occurring anymore, might be an issue with the operating system. So up until now all is working fine again with no issues whatsoever
