January 14, 20197 yr Hi, I recently dropped Lastpass in favor of Enpass 6, and so far I'm loving it. However a feature that can be improved, especially for power users, is the webform mapping screen. I am currently using the Windows 10 version and the relationships between form fields and enpass items seem to be read-only (apart from selecting a item field to map to) and can only be captured by browser extensions. A lot of those fields are required during sign-up, but not for further logins. I would like to have the ability to manually edit the webform mappings. Specifically, I would like to: Create webform mappings for manually created enpass items / logins Rename form field ids Add or remove form fields Add or remove "additional fields" Note: this could also be used to map TOTP fields to the webform, as also requested here Edited January 14, 20197 yr by Gizzy Removed tags, thought they were only for SEO
January 23, 20197 yr I recently moved from 1Password to Enpass. I love it so far, but the modification of the webform mappings would be really awesome, especially removing them :/
August 27, 20197 yr I agree. The ability to edit webform mappings would be extremely useful. Often sites require a user name and another identification number and without the ability to edit the mappings, Enpass can't be used properly for these sites.
August 27, 20197 yr Hello @DPN, Thanks for using Enpass. Please note that editing webform mappings is in our roadmap for future releases. Thanks.
February 13, 20206 yr +1 for the manual webform editing. For me the most painful shortcoming of Enpass.
February 17, 20206 yr Hi @willydee, Thanks for the feedback. We are working on the app to make it better for the users and we are listening to all the customer feedback to make the product better.
May 1, 20206 yr On a chromebook. I literally have to remote into Windows VMs to use the operating system. Chromebooks live with Enpass as an android app. I really need to be able to start working with the webforms myself. I have a couple of complicated logins that Enpass is totally incompetent at filling in. Please get webform editing on the Android roadmap as soon as possible.
May 4, 20206 yr Hey @databoy2k Thanks for writing to us. We have noted your request and forwarded to the concerned team. Thanks.
May 21, 20206 yr Hey @elitesonny Welcome to the forum! Thanks for reporting this issue. I have noted down this issue and notified the QA team to look into it. Thanks for your cooperation.
May 22, 20206 yr Hi @elitesonny Thanks for the patience. I would like to share that the issue has been reproduced by the QA team and assigned it to the Dev team to look into this. Thanks for your co-operation.
June 21, 20206 yr Is there any news on this yet? I have over 300 entries in Enpass and would like to remove the web form mapping from many of them, as this is no longer correct and causes some issues on many websites for me. Now I would have to create all entries again (this could take hours), because I can neither edit nor delete the mapping. Especially the deletion would be very very helpful. Edited June 21, 20206 yr by SVM
June 22, 20206 yr Hi @SVM, Thanks for using Enpass and writing to us. We are already aware of this, and our Dev team is working on it. The suggestion has already been in our roadmap and aligned to be implemented. Till then, we will request you to please co-operate with us. Thanks!
March 17, 20215 yr Hey @Ahmer Thanks for asking. Glad to share that the feature to edit web-form mapping has been implemented with Enpass v6.6.0.
April 10, 20215 yr Hey @Garima Singh Thank you for sharing that the feature to edit web-form mapping has been implemented & I'm really happy to hear that. I'm on Enpass v6.6.1 (store and win32) however I cannot seem to find the appropriate settings to edit a web-form after it has been mapped. I haven't found anything in the manual on the website or its pdf version either.
April 13, 20215 yr Hey @Ahmer Thanks for writing in. To edit the mapped web-form, click on Show Webform option given at the bottom of the particular item detail page. Also, we have noted your suggestion to add the same in our user manual and notified it to the team. Attaching a screenshot for your reference.
June 11, 20215 yr @Garima Singh My Enpass most of my entries do not have that "Show Webform" button, and there is no way to add it. Also, for the few that do have it, I have no way of editing the form tags, only the values. Some of my webpages have changed their web forms, which has broken the saved keys and there is no way to update the Enpass Entry's web form data. I try to click the key name such as "access key" but nothing happens. It is not editable, all I can do is delete mapping, or change the value fields and nothing else.
June 17, 20215 yr Hey @flamewave000 Apologies for the delay in response. On 6/12/2021 at 1:11 AM, flamewave000 said: My Enpass most of my entries do not have that "Show Webform" button, and there is no way to add it Enpass saves the Webform data only when you add the item via Enpass Extensions, manually creating and saving the data from the Enpass app doesn't have this option. Also, Enpass only gives the save Web-form option if there are username and password field in the Web-form page. On 6/12/2021 at 1:11 AM, flamewave000 said: Some of my webpages have changed their web forms, which has broken the saved keys and there is no way to update the Enpass Entry's web form data. I try to click the key name such as "access key" but nothing happens. It is not editable, all I can do is delete mapping, or change the value fields and nothing else. Currently, there is no way to edit field value type of save Web-form data. We will recommend you to re-save the web-form data if its broken. In this process, it will update new web-form, without need to manually change it. Thanks!
July 25, 20215 yr Hello @Garima Singh if deleting and re-creating the webform is the recommended way, how is this done? I cannot find any documentation on this. I deleted an inaccurate webform, went to the site while enpass was unlocked and the plugin active, but I was not offered to update the existing entry (or its webform) Best wishes Christoph
July 26, 20215 yr Hi @Christoph Sonnen, Welcome to the Enpass community. Once you’re done filling the details on a website sign up page, click the Enpass Assistant icon → click on ≡ button → Save Webform. Enpass will detect all the fields and will automatically create an item with the details filled in. You can verify the details and finally Save the item. For more details refer to this link of our user manual. Thank you.
April 21, 20233 yr Hi Community Last Update to this is a while back :-) It is still not working properly, actually I feel that ANY option to edit or create Webform entries is gone? This is seen with Enpass 6.8.5 (1238) version, localized to German. Am I the only one having that need / problem.
April 24, 20233 yr Hi @Christoph Sonnen I would like to share that Enpass displays the 'Save as Webform' option if the webpage has a password type field. If the webpage has a password type field and still you are not getting the option to save Web-form, then please let me know the URL of the websites on which you are facing this issue along with the Enpass app, Enpass Extension and browser version you using on the same device.
