Syd Posted January 27, 2020 Report Posted January 27, 2020 Lifetime Premium user. any ideas on how to enable or is this a bug?
Pratyush Sharma Posted January 27, 2020 Report Posted January 27, 2020 Hi @Syd, We are sorry for the inconvenience caused to you. Please follow these troubleshooting steps and let me know if the problem persists. Which Enpass version you are using Website or Store? Goto System Preferences --> Touch ID --> Check Touch ID is Enabled. Also let us know are you facing this issue when you are using your system is Clamshell mode? Thanks for your co-operation.
Syd Posted January 27, 2020 Author Report Posted January 27, 2020 (edited) 4 hours ago, Pratyush Sharma said: Goto System Preferences --> Touch ID --> Check Touch ID is Enabled. I'm using version 6.3.3 (584) It's working on 10.14.6 on the hardware - will check on 10.15.2 and report back Edited January 27, 2020 by Syd
Sergio Posted February 15, 2020 Report Posted February 15, 2020 I also have this issue, started suddenly today just after My MacBook Pro 2018 updated to 10.14.6. Moreover if I try to enable PIN the following message is shown, in which you can clearly understand that the touch id was previously configured:
Tahreem Posted February 17, 2020 Report Posted February 17, 2020 Hi @Sergio, Could you please confirm from where did you install the Enpass app from; the store or the website? Please let us know so that we can check this further. If you have the store version, please try re-enabling the Touch-ID and let us know if it helps.
Create an account
Register a new accountSign in
Sign In Now
