Unlock with TouchID options keeps disabling by itself after a few minutes
Nishant
I am an Enpass Pro member and I am currently using Enpass(version 6.3.2 (582)) on my Macbook (version macOS Catalina version 10.15.1)
The 'Quick Unlock' with Touch ID option is being auto-unchecked after I manually enable it. This happens almost immediately after I enable it. Please check the screenshot below. Is anybody else experiencing the same problem. Trying to see if there is a fix to this problem. Thanks in advance!
Edited by Nishant
Added the Enpass Pro proof
  • Thanks 1
Link to comment
Share on other sites
The beta seems to work for me.  Downloaded v6.3.2 (599) it prompted me to update to v6.3.2(601). After update to v6.3.2(601) I selected TouchId in prefs and  it seems to be working.  TouchId setting is still persisted after an app restart.  So far so good.
  • Like 1
Link to comment
I just tried the beta again, and the process unfolded differently this time -- just as described by twm40. Now the touch-id setting is sticking.
Now, if only the application would go straight to the touch-id verification without requiring the user to click the fingerprint icon.
Edited by J P
  • Like 1
Link to comment
Yes, I agree, this is the behavior it should have. 1Password does this; no reason Enpass can't.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
